Hi guys, I was wondering if anyone knows how to adjust the oil pump on a 2005 90hp 2 stroke. The motor doesn't smoke at all and I'm concerned that it isn't getting enough oil. Any information would be great thanks
How to adjust oil pump on a 2005 90hp 2 stroke
You might try putting a piece of tape on the oil tank level and run it seeing if the level goes down...
You may also run a pre-mix in the mean time (with the injection), just in case it isn't operating/clogged, etc.
As for the specific adjustment, IDK. Either in the shop manual or someone else will chime in...
Your oil tank / pump:
http://www.boats.net/parts/search/Ya...UMP/parts.htmlLast edited by TownsendsFJR1300; 07-15-2016, 11:56 AM.Scott
Oil pump
Thanks for the ideas guys, I checked the linkage on the oil pump and it is definitely using oil because I regularly have to add oil. My concern is that it is not getting enough oil simply because it doesn't hardly smoke at all. I have a 115 v4 2 stroke same year I bought new with way less hours and it smokes a lot more. The 90 I bought used and I know it has had a much tougher life and doesn't smoke. I was just wondering if the oil pump should be turned up if that's possible. Thanks again
