f70 loosing rpms and sometimes shuts off when putting in reverse
  • f70 loosing rpms and sometimes shuts off when putting in reverse
    i have a 2011 f70 with just over 400 hours. im having problems at wot it seems like the boat especially with weight in it will loose rpms and slow down ive had the injectors cleaned and they did find some dirt and ive also changed all the fuel filters. ive also noticed that sometimes when i put the motor in reverse quick it will shut off but not all the time
    do you have any questions for us?
      yeah i would think the words shut off would make you think im having a problem but why is it loosing rpms and question number 2 is why is it shutting off in reverse? might be the same problem for both i dont know
        High RPM drop could mean fuel pressure problems, monitor those to see.
        as far as shutting off when quickly going into reverse, hard to say
        may be it is running lean at idle and cannot stand the load put on it
