ok
you DO NOT and DID NOT have a VST issue.
you DO have a lift pump/leak issue.
if the VST has no fuel the engine quits.
just like your car will when the gas tank is empty.
find the VST supply issue.
the fuel cooler is rather simple.
its a big aluminium block with two tubes.
one tube has water flowing the other tube has rail return fuel flowing.
it is not your supply issue.
