Since Im loosing sleep thinking what im doing wrong I forgot to mention with the motor vented directly when I started after being warm I did have some fuel come from the vent . There was a long thread on the hull truth where a lot of others have or had the same issue. They kept on calling a vapor lock .
Fuel starvation yamaha f225
I believe Rodnut mentioned and/or I read about an anti siphon valve in the system before the fuel pump.
Not 100% on that location...but would make sense to me that this valve (check valve) would prevent the fuel from being siphoned back towards the fuel tank when fuel pump is off....
Again this is just from memory, so check your SM to see if this actually part of the system on your engine. I don't want you to go chasin ghosts...
the anti-siphon valve,if equipped,will be located on the fuel tank draw tube.
it can act as a check valve but that is not what it is designed for.
the check valve in the fuel primer bulb should stop some of the fall back but that is normal.
that is why the pump runs 10 seconds.
I still don't think the vst's are staying full.
Originally posted by marchmadness View PostYes I’m still on it . And yes my good motor is starting to get the same systems. Yesterday I hooked in a plastic tube before the filter. It appears that the fuel drains back when the pump starts it’s cycle. Is it supposed to stay full?
or when it turns on?
starting a cycle to me means start up and then turning off
I will try to slpain this one mo time.
the fuel delivery system on this F225 is like this.
a lift pump supplies the VST with fuel.
lift pump below 1200 RPM cycles at ten seconds on 20 seconds off.
the output of the lift pump fills the VST until the needle valve in the vst shuts.
if the lift pump is still on when the needle shuts the excess output is routed through a relief valve that opens at 10 psi back to the lift pump intake.
if there are any air leaks in the pump intake OR the relief valve leaks it starts introducing air into the lift pump intake.
now the VST starts running low.
so when your idling while setting ancor or whatever then you restart and idle while getting ready to get underway the VST is using fuel but not receiving fuel.
then whammo you nail it to get rolling.
about 60-100 yards into it uuuggghhhh.
vst is out o gas , nothing for the HP pump to supply the injectors.
motor dies.
the VST and high pressure system is working.
the lift pump works.
find the air leak or fuel restriction between the lift pump intake and the liquid level in the tank.
Rodbolt thanks for being patient with me. So you would suspect that the vst never fills? when im running it is always playing catchup ? Then if I was at your shop, and I wish I was, where would you start looking? These motors are equipped with fuel monitors could that be a source of restriction? I guess what's throwing me off is that this only occurs after shutdown.
The VST is filling however once stopped, the fuel in the system (hoses, primer bulb, etc), is RUNNING BACK OUT to the fuel tank.
The engine starts and runs on what's LEFT in the VST for a couple of minutes. Then, with the fuel in the lines DRAINING, you have air in the system, there is NO fuel.
Do you have a fuel / water separator? Have you checked the sealing surface / o-ring gasket there? As noted earlier, the primer bulb should help keep fuel from flowing back into the tank..Scott
