I'm still somewhat confused as to why pumping the primer bulb (boosting the line pressure to the vst) was helping to keep motor running when it started to stumble.
I understand that , at idle speed, under load, the motor isn't using much fuel and that the fuel pump doesn't speed up or slow down related to RPM's so probably 95% of the fuel is being recycled thru the pressure regulator and down thru the non-functioning fuel cooler , then returned into the bottom of the vst. I also read that , under a vacuum, the boiling point of ethanol blended fuel can be as low as 50 degrees F. ( much lower than non-ethanol 87 octane )
I try to run non-ethanol fuel only, but lately I have been topping off my tank at the local c-store with ethanol blend 87 and adding a dose of Biobor EB.each time.
My theory is that , without the fuel cooler able to function, the bypass fuel is constantly being recycled thru the heat producing fuel pump until the boiling point at the fuel pump pickup (vacuum) is being reached, thus creating the vapor lock situation inside the pump itself. When I pump the primer it's allowing a little fuel ( much cooler) into the vst where the cooler fuel wants to settle to the bottom and thus drop the temp of the fuel there to below the boiling point?
A couple of trips ago, I started off my *****ing run with the cowling off and it never stumbled and died even after a couple of hours at 700 RPM's. I then replaced the cowling and ran mid-throttle back up the lake , dropped back to idle, and the stumble started after just a few minutes. The cooler air without the cowling on , (I presume) allowed enough air flow around the VST to keep the fuel slightly above the boiling point.
