Thanks for chiming in, Rodbolt. I'm just doing the best I can to keep my boat. If I can't make it idle at *****ing speed on the water, It's useless to me. Wifey says I've already overspent on this thing and if it won't fish it has to go....It's running with 5 lbs. pressure between the lift pump and the VST. the small filter between the lift pump and the VST is new (did the same on the old filter), The fuel hoses from the gas tank to the VST have all been replaced. The fuel filter before the lift pump is new also. All the spring clamps that Yam put on this motor have been replaced with screw clamps. It only messes up on the water, never here in the yard. You say to fix the leak/restriction between lift pump and tank? What else is there that I could possibly fix???
Thanks. Fred
Thanks. Fred
