90HP Yamaha Not Peeing well! Solution?
  • 90HP Yamaha Not Peeing well! Solution?
    My 2001 90 HP 3 cyl. Yamaha is not spurting water out of the top hose very well. I have been told the water line may be clogged. Any ideas for the best way to clean it out? Iam boatless until I fix it.
    With the motor running on the garden hose, stick a length of stainless wire or heavy monofilament line up into the pee hole to clear out whatever may be blocking it. Other than that you maybe looking at replacing the waterpump.
    Mike....... Miami,FL
