2003 250 EFI outboard
  • 2003 250 EFI outboard
    Hello group, I bought another Yamaha outboard, this one is a 250 salt series 2 stroke outboard
    The previous owner removed the oil system, and now that I have installed it,
    It gives me a long buzzer signal, I assuming it has to do with the missing oil system.
    Is there a way to trick the ECU into thinking the oil sensor are full?
    The wires colors to the float switch which is missing are Black, Blue,White, blue,green, and 2 blue,red..
    Many thanks...
    May need to verify that is what the alarm is indicating first.....
      It takes a few seconds but after I turn on motor the buzzer goes off
      Water temp it warm at best...
        does the buzzer go off or come on after starting the motor or after turning the key switch to on.
        I am confused
        and what do the gauges tell you the alarm is?
          buzzer
          I put the key inside, turn motor on, and after a few seconds the buzzer goes off
            2001 Yamaha SX250TURZ 250.0 hp
            Ok I fixed one of the alarm problems, It was the thermostat, they were not opening.. Now the other alarm problem is that once I turn the key on, the buzzer goes off, then after 45 seconds it turns off, but I can't go over 3300 rpms..
              bump
              Can someone help?
              Thanks in advanced...
                Not sure why a buzzer would sound off and then quit sounding after 45 seconds when key is turned to the on position but motor is not started,
                unless the oil tank is low and it filled as it should when you turned the key to the on position
