HI Everyone! I have twin 200 Yammies, one is running great, the other is making me pull my hair out!
There are 2 fuses on the port side of the engine, a 20 amp and 30 amp.
The 20 amp controls the tilt motor, among other things.
I kept blowing the 20amp, and I noticed there was an internal continuity problem in the fuse holder itself, as when I wiggled it I would get intermittent power, ie, the tilt motor would function and the ignition buzzer would activate.
Figuring the contacts were dirty, I cleaned them and compressed them to make sure they "gripped" the fuse firmly. This helped for a little while, but now when I run the engine, the 20amop fuse keeps blowing, whether I am at WOT or not.
Sometimes it will run for 10 minutes, or it may run for 1/2 hour w/ no issues.
What load(s) or device(s) does the 20amp fuse control on the motor so that I can check for shorts? Is there a temp switch or thermo switch in the loop,
that could blow the fuse?
Thank you for any ideas!
