I have a Yamaha F100A -99 outboard with carburetors. It runs great during idle or high speed. However, when I tried to do waterskiing the engine stalled when throttle stick was turned on full at a fast pace. It only worked when throttle was used gradually. Propeller is 13.2*21 aluminium.
It just does not respond under hard acceleration as I would expect.
Does the engine has a accelerator pump, is that part 43? 1999 F100TLRX Yamaha Outboard CARBURETOR 1 Diagram and Parts (names are wrong, 43 should be "diaphragm assy 2").
Are the carbs clogged (I have used carb cleaner solvent)? I suspect no, since there is no problem during idle or fast run?
Where is the problem? Accerelator pump (if any) gone or carbs are out of sync?
