Hi, I ve got a yamaha F4A on which the can axel has broken . Can i fix it myself without any special tools ? Also i d be greatful for any tips as too where i can buy parts at a good price .
F4a
Cam shaft!!
Here's the closest thing I could find close to your engine:
2006 and Later F4LMHA Yamaha Outboard VALVE Diagram and Parts .
Its a single cam inside the engine block. It'd be best to buy a service manual
for exactly how to change it.
Per this fisch:
http://www.boats.net/parts/search/Ya...TON/parts.html the cam runs directly off the crankshaft with the gear(s) being closer to the mid section(or lower side of the engine).
So the engine would need to R&Red from the mid section, and the cases split:
http://www.boats.net/parts/search/Ya...202/parts.html
Not being an overhead cam engine, its basically like changing the cam shaft out on an older mower engine.
Why do you think you need a cam shaft?Last edited by TownsendsFJR1300; 06-26-2016, 03:41 PM.Scott
Â
