this is a motor I bought 2 years ago, and have had sitting since
when I bought it, she started easy and strong, but would slowly quit due to fuel pressure drop
I could nurse the prime bulb to keep her going, so diagnosed it as bad fuel pump
last summer, had a family health crisis, and boat stuff got neglected
just replaced the fuel pump tonight, but she is not firing
I have not pulled plugs yet, but that's next
she is acting like lanyard switch is faultly - cranks and cranks, not a hint of fire - used to be chick-vroom - no need to crank at all
so I unscrewed front end of the switch, which *should* un-ground the power lead, correct? same as pulling the yellow/black wire? (in my case, white)
if there's a different way to temporarily bypass the lanyard switch, I'd love to know (it is not obvious how to disconnect a lead from the rear of the switch - kind of looks like someone replaced the switch - doesn't seem as robust as a typical Yamaha part)
any thought greatly appreciated
I will try to post a couple pics and a video
https://youtu.be/PC8ZV5jCAVg
