Hello first time to all, and thanks for reading this.
My 2005 60HP 4 stroke (F60CET) is showing a flashing engine light on the dash. Its got to be a code as its 2 consecutive flashes, then a pause, then 8 consecutive flashes.
Is that code # 28 ?
If the answer is 'yes', my workshop manual for this model states that this fault code relates to the neutral switch on the engine, and it does appear to be shot. I could not get a continuity reading on my ohmmeter when the switch lever was in either position, i.e. neutral or in gear.
However, the engine will not start when its in gear (as you'd expect), and does start when in neutral. So...is the switch really U/S ? Or, is it there to do something else ?
Hoping someone can help ? Thank you .
Is that code # 28 ?
