1987 40hp throttle linkage
  • 1987 40hp throttle linkage
    HELP!! I got no rpms What makes the throttle plate linkage activate? the rods on the one side are all hooked up and when I move them by hand it moves the arm on other side of carbs and everything looks right?? the single arm looks like its attached to oil pump ???is it pressure activated ? Its been running great than lost about half my speed than after few more minutes basicly runs just little over idle. In gear pushed all the way forward the carb linkage never moves but if I move it by hand rpms come up and runs fine ??
    Sounds like a simple cable change is due.
