Bought boat used from dealer sun coast inflatables dealer said engine worked great. Turned on key in driveway but did not start and noticed the over heat indicator was flashing lower left corner. Ran engine first time on lake and would not plane or go over 2,000 rpm. No alarm sounded. Took to mechanic who said water pump housing had failed and metal cup was spinning with impeller. Changed out pump housing and light still blinking. Had him check alarm by starting with no lanyard and still no alarm. I saw post about how Yamaha instrument s are set up as 4 stroke and not 2 strokes. Does this cause overheat to blink and not sound buzzer? I read that improper set up will cause oil level to not read 3 bars only far right. I have blinking bar on left and sold bar far right.
Thanks in advance
Thanks in advance
