Hi all. Brother in law's 130BETO has a 2 Yamaha 25L fuel tanks both obviously with Yamaha connectors, so we can switch easily from one to the other.
He has just bought a 5hp Honda auxiliary which has no tank, just the hose connector. He doesn't want to buy a dedicated Honda fuel tank, as hopefully it will be used very rarely, and don't want the fuel going off etc. We want to buy a Honda hose and bulb with both engine and tank connectors and cut off the Honda tank connector and fit a Yamaha, so it fits both existing fuel tanks No mixing required, so just pure fuel in the tanks. Yam is auto lube and Honda is 4 stroke.
Question is, if the hoses are different diameter, will that affect the fuel flow rate into the Honda if the Yamaha is a bigger diameter hose, and flood the engine?
Hope that's not a daft question!
Thanks,
John
Thanks,
John
