F225 Relief valve and air orifice vent?
  • F225 Relief valve and air orifice vent?
    Hi all,
    My 2002 F225 has a 69J-13490-00-00 relief valve into the air intake. I was looking at the parts diagram for a 2005 F225 and it has both of these parts off of a tee going into the air intake.
    69J-14989-00-00 ORIFICE, AIR VENT
    60L-13490-00-00 RELIEF VALVE ASSY
    Anyone know why and/or what the added air orifice vent that was is for?
    Thanks,
    Bob
    the 2005 has a carbon canister on the VST vent line, as well as the "orifice" going directly to the intake silencer.
    The "orifice" does not seem to be a "mechanical valve" like the "relief valve assembly" but rather just a very low flow restrictor.
    The vapor that makes it into the carbon canister via the one-way "relief valve" seems to be eventually "sucked back out" through tubing to the IAC valve.
      here you can see the "orifice"
      coming from the "tee" in the VST vent tubing
      and going to the intake silencer
      upper left: the "relief valve assembly" in the VST vent line,
      acting as a one-way pressure relief to the carbon canister
        Got it.
        Thanks for the reply.
