F250TXR Thermostat Location
  • F250TXR Thermostat Location
    Can somebody please tell me where can I find the Thermostat on a Yamaha Outboard 2007 F250TXR 4 Struck
    I just bout the part with the gasket But I can't find them on the motor,
    I will appreciate your help,
    Thank you,
    Top of the block. Just forward of the cylinder head. Should be a rubber tube running to the outlet of the thermostat cover.
    Item 20 in this illustration.
    2006 and Later F250TXR Yamaha Outboard CYLINDER CRANKCASE 1 Diagram and Parts
      Hi boscoe thank you very much for your pronto answer. Now I have 2 mor question,
      -Looking at the illustration and now at the engine I see that I have 2 thermostat? If yes, I need to buy another one.
      -if the thermostat cover is the one that has rubber tube, that part has only 2 screws horizontally and the gasket I bout (63P-12414-00) has 3 screws.
      - Next to the cap mentioned above there are another cap on the engine with 3 screws vertically similar to the gasket I bought, but this one has not rubber tube. I was wandering if this one with the 3 vertical screws is the thermostat cap.
      Thank you
        63P-12414-00-00 is used on an F150. Not an F250.
        63P-12414-00-00 YAMAHA GASKET, COVER
        The F150 uses one thermostat. The F250 uses two thermostats.
        The parts catalog does not show the F250 as using a gasket. It appears that the housing is sealed to the block via a rubber seal that fits onto a flange on the thermostat.
          boscoe,
          I really appreciate your help and clarification.
          Thank you.
