New member here - have already learned a lot from browsing. Thanks for the site.
I have a 2004 F25TLRC. Has run perfectly for several years. This spring would not start - no spark at plugs. Suspect rectifier since my assistant first hooked up battery with wrong polarity and tried starting it. Believe rectifier may have been damaged with incorrect polarity. Before I spend $170 on a new R/R, is there a simple way to test it? Any other component I should suspect? I've checked all electrical connections and fuse - seem OK.
Finally, are aftermarket rectifiers (CDI) better than OEM as claimed?
Many thanks,
Jim
Many thanks,
Jim
