Need some help!
I have a year 2000 Saltwater Series 150HP
I hadn't had the boat out in a while and my battery was weak. It had enough juice to lift and lower the motor but didn't have enough to turn the motor over when I tried to start it. I pulled the battery out and charged it. Now that I put the battery back in I am not getting any power to the motor or trim. I am getting power to everything else (lights, aux switches, etc.) The battery is reading 12.6 volts on a volt meter. I don't even hear a click from a relay or anything. Is there a main fuse or something that I should look for? If so, where is it located? I tried to look for one on the motor but didn't see it.
Thanks in advance for the help!
