The F70 uses electronic fuel injection. The computer senses when the engine is cold and provides for automatic fuel enrichment to give the cold motor the extra gasoline that it needs for start up and warm up.
The operator does not have to do squat. Just turn the key to the start position and wait for the motor to fire up.
Yamaha refers to this as PrimeStart.
PrimeStart™ – Yamaha’s auto-enrichment system provides
consistent adjustment-free starting in all climates.
Be glad you don't have an F250. That damn thing sounds like it is going to run away when it starts. I hate it.
What's up with that anyway? My F150 truck does the same thing.
And yes, let the motor warm up and drop to its normal RPM before shifting into gear.
My 01 Toyota 4 Runner does the same thing.
The bike, I have the idle set lower than recommended and on cold start, (about 1,100 RPM's warmed up), might be 1,300 RPM cold
The F150 OB, 8-900 RPM's cold, the water is about 80F now, so it'll start at about 800 cold, and drop to 700 in maybe 2 minutes...
I don't know why cages are generally set to run so high on initial cold start up (when most of your wear occurs). Maybe a throw back to the old days when most used a "coil" and expanded, opening the choke and lowering the idle as the engine warmed...
Now a-days, there's no reason with all the electronic's, they'd let the computer adjust accordingly to conditions...
