I have a twin set of 2005 250 4 strokes. The port motor acted like a dead battery just clicks when key turned. I replaced the starter and tested all fuses and swapped out relays. Same end result! The 4 batteries all test the same and I see 12 volts where the cables attach to the motor. I have the switch on the battery box set to "ALL BATTERIES" the starboard cranks right up. The port engine barely produces a faint click. What next, Please.
THANKS!!
![Frown](https://www.yamahaoutboardparts.com/core/images/smilies/frown.png)
