2016 Yamaha F90LA trim gage wiring
  • 2016 Yamaha F90LA trim gage wiring
    Need help wiring a new analog trim gage on my new 2016 Yamaha F90LA
    4 stroke outboard. Can I buy a trim gage wiring harness or can I just run two wires from the gage to the connector on thr starboard side of the motor?
    Also there are four wires in the connector I found on the motor but I don't have the wire color designations to know which is the sender and which is the ground if I decide to just run a pair of wires. Could someone advise the correct wires to tie to and if there is a Yamaha trim wiring harness or pigtail connector I could just buy if available to make the job "plug and play".
    Thanks in advance for any help provided !!!
    Bernie88
    4 stroke outboard. Can I buy a trim gage wiring harness (Yes) or can I just run two wires from the gage to the connector on thr starboard side of the motor (Yes) ?
    Bernie88
    Pink is the sender wire colour.
    Diagram below shows the plug and play configuration if a Yamaha tachometer and trim meter are used.
