View Post
My motor is the 9.9MSHY. In my case it would be items 15 (spacer) and 16 (washer plate). I will verify the parts when I get home although i doubt they're stamped with a p/n but I think I have back ups of both still in the Yamaha packaging and if so I'll compare the two side by side. I'll also post pics of the pin and how when installed is too far to fit in the grooves of the nut without backing the nut out. I'll get pics of whatever spacer and washer parts I do have as well.
2000 9.9MSHY Yamaha Outboard LOWER CASING DRIVE 2 Diagram and Parts
Also, my prop is one of the ones listed below. I believe the one I underlined but I'll have to verify. Same for 9.9 and 15. If I remember right, when I changed from 9.9 to 15 I went one pitch up from what was on it from the factory (I know that statement doesn't tell much)... even still these are all listed to be used with my motor.
A AMITA 3
9.9, 15
3 9.25 7 R 3111-093-07
3 9.25 8 R 3111-093-08 3 9 1/4 8 R 683-45947-00-EL
3 9.25 9 R 3111-093-09 3 9 1/4 9 R 683-45945-00-EL
3 9.25 10 R 3111-093-10 3 9 1/4 9 3/4 R 683-45952-00-EL
3 9.25 11 R 3111-093-11 3 9 1/4 10 1/2 R 683-45943-00-EL
