are carb parts still available for a 79 2 stroke 15 hp
  • are carb parts still available for a 79 2 stroke 15 hp
    can any direct me to carb parts for a 1979 15 hp model w15 2 stroke?
    Do you know the part numbers that are needed?
    Plug them into the parts search box at this website and see.
      no I dont know the part numbers, I believe the problem is the fuel filter/strainer on side of carb the , fine mesh screen has a hole in it and gasket is blown.
        What is the complete identity of the motor? Both model and the primary ID. The latter will begin with the number 6.
          Should that screen NOT be available, most small two stroke carbs (Walbro) have a filter similar to that (if not the same) right before the float needle.
          That filter would come with a carb rebuild kit,
          IE:
          Genuine Walbro K10 WLA Carburetor Repair Rebuild Kit Fits WLA Series | eBay
          Its right next to the needle in the pic if you zoom in.. Its cheaper if you look around..
