I'm about to install a water pressure gauge on my 130 Beto -95. Found a used Yamaha gauge that says kg/cm2 instead of psi and since I'm European that's nice.
Bought the sender tube from my local Yamaha dealer and found that there is a little brass restriction in each end of the hose. Since the tube is to long is it ok to simply cut the hose in the gauge end and discard of the restriction in that end? Does anyone have any installation instructions to a WPG?
