Ok so I'm not new to boats just new to ones with a tilt/trim.
Just changed tilt/trim motor and both relays. When I push the button you can hear the motor working which is an improvement because with the old motor there was no noise. It took a couple minutes but the 2 little pistons came out but the large piston never moved. The trailer sits low so the motor doesn't sit on the 2 smaller pistons it just sits on the ground. I held the button down for a couple more minutes hoping the large piston would lift the engine but nothing.
Any advice or suggestions are appreciated!
