Good afternoon,
I am hoping to gain some insight on an issue we are having with the twin F350 engines on our 2008 Contender 33T.
Two weekends ago we left the dock on Friday afternoon for a weekend-long fishing tournament. Our 3 batteries were fully charged and the boat was running great. We ran at 4600 RPM for a couple hours and then slowed down to just over idle once it got dark. We continued on our course for roughly 6 more hours by only using one engine, alternating the engines every couple of hours. during this time we were running radar, GPS, bottom machine, 2 livewell pumps and, of course, the stereo. We also had spreader lights on occasionally.
Once tournament hours started, we fished for about an hour and then started getting low voltage alarms from the gauges and electronics. A few minutes later we lost all power on the boat.
We had a jump box on board and used it to jump the engines, but they died almost immediately after engaging the throttle. We then used the jump box to start one of the engines, and it was able to idle in gear for 10 minutes before losing power. We checked all connections and grounds (that we knew of). Once we determined that the issue was more than something simple, we called Tow Boat US on the satellite phone and had them bring us 4 heavy duty marine batteries. Once we received the batteries, we hooked one up to each of the engines, cranked them up and the engines ran like a top. We started heading in at normal cruising speed and could watch the battery voltage slowly drop. Eventually (several hours), the port battery was too low for the engine to run and the motor shut off. At that point we installed the last two batteries and were able to make it all the way back to the marina without losing power again, but the battery voltage had dropped substantially.
One of our good friends is a Yamaha mechanic and he was willing to go down to the boat and hook up the diagnostic computer with hopes of helping us troubleshoot the issue. These are the codes that were picked up:
Port Engine:
Engine R/C Communication Code 156
Engine R/C Communication Code 157
ETV Code 144
Pulser Coil Code 13
Battery Voltage Code 19
Starboard Engine
Pulser Coil Code 13
He also said that he was able to confirm that there was no power coming out of the engines, headed to the batteries (I am not sure which points he checked).
I am hoping that some of you experienced Yamaha techs would be willing to weigh in on this situation. The boat is kept on a lift, and we do not have a trailer, so we would like to do as much homework as possible before developing a plan to have the situation addressed.
Thanks in advance for any advice given!
-Dan
Tallahassee, FL
Port Engine:
ETV Code 144
Pulser Coil Code 13
Starboard Engine
Pulser Coil Code 13
-Dan
Tallahassee, FL
