I have a 2001 Yamaha 2 stroke TLRZ115 that runs well when cold, after fishing a few spots it seems to not be getting enough gas but will catch up and run ok, after my last outing I noticed that the primer bulb was not firm and could be pumped several times, is it possible that it is getting air in fuel system? where should I be looking other than fuel line and primer bulb
yamaha 115 2 stroke
Originally posted by countrytn View PostI have a 2001 Yamaha 2 stroke TLRZ115 that runs well when cold, after fishing a few spots it seems to not be getting enough gas but will catch up and run ok, after my last outing I noticed that the primer bulb was not firm and could be pumped several times, is it possible that it is getting air in fuel system? where should I be looking other than fuel line and primer bulb
If engine has no difficulty starting this way, I don't see a problem.
But yes there is a possibility you have a leak between the bulb and tank system, however would also show up as poor running.
Check every fitting carefully. Once, I had this problem, and it was a leak in the gasket around the spin-on water separator.
But definitely find it, as sucking air can cause a lean condition, which can be fatal to an engine.
Best wishes.-Tony
Originally posted by thilltony View PostCheck every fitting carefully. Once, I had this problem, and it was a leak in the gasket around the spin-on water separator.
You may want to check any seals at the under cowl fuel filter too...Scott
