Hi All
My name is Raymond and I stay in Port Elizabeth South Africa.
I have a 5.2m inflatable boat with a 85 Yamaha.
The motor is a 2002 model. I had this boat for 3 years now.
The last year I noticed a small problem. The motor starts fine and idle well.
The motor idles warm when I park the trailer and then I continue slow speed from the launch out the river. Out on the river when I starting to speedup you can hear and feel that the motor is running on two cylinders only. The boat wont go on plane. I tried going back to neutral and start speeding up slowly again but with same result. When keeping the throttle halfway open for a couple of seconds the problem will go away and you can feel the power and hear the motor sounds good.
After that you can go to neutral and takeoff with no problem. When stopping for a short while and takeoff no problem. If I anchor and fish for a while I will have the same problem with the motor running on two cylinders. If you drive at idle speeds for a long period it wont come right. Only when you trying to speed up at higher revs the motor will come right.
I rebuild the fuel pump added a water trap. Had the carbs rebuild twice. Oil mixing ratio 50 to 1. Used new fuel. No difference between built in tank or plastic carry on tanks. Fitted new spark plugs.
Is there something I can try because the boat repair guys is making money and me losing. Please any advise or any thing I can try will be appreciated.
Regards.
Raymond.
Regards.
Raymond.
