i have a pair of 4 stroke f250b's, the starboard engine will crank but not start, there is no power to low pressure fuel pump with the key on and i have found that the high pressure pump is siezed, obviously i will replace the pump but my question is should i have power at the low pressure pump or does the ECM recognise a problem and keep the power off. no fault codes show up in the diagnostics.
