What does the damper seal do on a 2004 vz250 hpdi lower unit
  • What does the damper seal do on a 2004 vz250 hpdi lower unit
    Went to change water pump a saw minor damage to damper seal. Wondering if I should replace. It's quite spend at $60.
    Keeps exhaust gases within the exhaust system.
      And out of the water pump I believe
        Thanks for yor help
          Are you talking about this "Damper Seal", # 10 on the diagram in this link?2004 VX250TLRC Yamaha Outboard LOWER CASING DRIVE 1 Diagram and Parts Not 60 bucks!
          Chuck,
            That is the damper seal clip. OP is talking about the actual damper seal. Item 11 shown here.
            2006 and Later VZ250TLR Yamaha Outboard LOWER CASING DRIVE 2 Diagram and Parts
