Hey guys,
I Have a 2010 Yamaha F150 installed with the Yamaha Command link system connected to the three Yamaha square gauges ( Speed, Tach and Fuel Management). I am also running a Lowrance HDS7 that is linked into the "Multi hub" for extra various engine readings.
Everything that I want to display on the HDS7 about the engine is reading perfectly, accept for the "Engine Temp" reading. The reading on the HDS7 is reading about 12 degrees Centigrade lower in temperature compared to what the temp reading is on my laptop using YDS software.
Eg: This morning I hooked up my laptop and switched on the motor and the Lowrance, both temperature readings at cold were the same "16 degrees C" on both the displays. I started the engine and watched the readings as it was warming up to idle operating temperature... both would increase the same together until at about 48 degrees, this is when the YDS would start increasing higher than the reading on the Lowrance at a gradual rate..... and finally when the YDS reading stabilises at 62 degrees the lowrance is displaying 50 degrees...... its weird!!
The other readings : Oil pressure, MAP pressure, water pressure etc are all reading identical between the YDS, Lowrance and Gauges. Its just the "Engine temp" that is not playing ball. I have also done a physical check of the "Actual" engine temp with a digital temp gun aimed at the lug that the engine temp sensor is screwed into and its reading identical to what is displayed on the YDS ( did that for piece of mind).
Does anyone have a solution to this problem or any clues?.... I have been through the settings on the Lowrance but there is nothing relating to it for options.
Cheers
Scotty
Cheers
Scotty
