Pass the popcorn... NO, a switch is not a sensor, a switch can be turned on or off, nothing more, nothing less, a sensor is variable, and can be on, off, or somewhere in between, it can display various values, like on an old fashioned gauge where the "needle" moves around as (say) temperature increases, it can operate with no mechanical connection to activate its function, but by change in heat or pressure for instance.
Oil alarm issue 200 hp HPDI 2000
Originally posted by ausnoelm View PostPass the popcorn... NO, a switch is not a sensor, a switch can be turned on or off, nothing more, nothing less, a sensor is variable, and can be on, off, or somewhere in between, it can display various values, like on an old fashioned gauge where the "needle" moves around as (say) temperature increases, it can operate with no mechanical connection to activate its function, but by change in heat or pressure for instance.Scott
