I have two issues with my 2003 F115 that I think may be related.
1. The engine runs really well, but over the last 12-18 months I have noticed that the number of seconds of cranking required before it fires has noticeably increased.
2. Over the last 6 months it has developed a hot start problem. The motor starts up normally at the ramp, runs well. If I shut it down once it has reached operating temperature and I shut it down, it will not restart. I can restart it if I wait a little while, this can be accelerated if I advance the throttle. This sounds very similar to the vapour separator chamber problems described elsewhere.
I've done the basics, compression test, overhauled cables, terminals, battery, new fuel, run direct from tote tank, ring free shock treatment, new plugs all without noticeable change.
Presumably need to check the fuel rail pressure? Why would this help with the hot start problem?
Engine is due for an impellor change (programmed maintenance) wondering if some small degradation in the cooling system and possibly the return fuel cooler has lead to this problem?
Thanks in advance
Phil
Thanks in advance
Phil
