Just had water pump replaced a year ago. Has been running great since. Peeing like a race horse. All of a sudden red light comes on and starts to shut itself down. Got depressed, took boat out of water. Took it out Sat. and Sun. and it ran great. Full speed, no prob. Skip ahead one week. Runs great for four hours, then red light again. What all things can make a red light come on and make the the motor force itself to idle down? Can water pump be going bad and still have strong pee stream? At my wits end. Help!!! Thanks, Keith
Red Light on Yamaha 25hp. 2 stroke
Originally posted by rodbolt17 View Postcould we get a model number?
Purpose of these questions is to challenge your brain. If you have all of the information you needed it would be an unfair advantage.
Try to do and be all things for all people with as little as possible to go on.
That is all. Carry on.
You think it might be low oil pressure? Of low oil in a remote mounted oil tank? Or water in the fuel warning?
could be.
about all I can tell from the post is it is a 25 HP of some type, it has a red LED and it occasionally goes into RPM reduction.
dunno if its a 3 cyl oil injected or a two cyl oil injected but my guess would be a low oil alarm.
Also forgot to say that when the red light came on we immediately took cowling off and nothing felt overly hot
Originally posted by caddysdad View PostAlso forgot to say that when the red light came on we immediately took cowling off and nothing felt overly hot
Two things in that model that normally sound an alarm. Low oil quantity and over temperature.
A defective thermoswitch can trigger a false over temperature warning and a defective oil level gauge assembly can trigger a low oil warning. Defective wiring can also cause false alarms.
Purpose of these questions is to challenge your brain. If you have all of the information you needed it would be an unfair advantage.Scott
Originally posted by TownsendsFJR1300 View PostYes, its that simple Virginia!
Ok i'll bite.
Which way do they flow?
+ to -
or - to +?
do you bump electrons out of place to cause them to move to the other atoms or remove some to cause a hole and get others to fill the void
flow + to - depends on if your civilian trained or military.
why I dunno.
I cant remember if the 95 25HP used an overtemp switch.
according to the tune up spec guide it does have one.
What time is it?
To me it is 1523 hours. To others might be 3:23PM.
Can't remember the number of bells.
+ to -
or - to +?
Story is that when electricity was first being discovered they (Ben Franklin I think) thought it was + to -. That sort of stuck even though it was later discovered to be just the opposite.
I have heard the "hole" story which to me seems to me to be just one way to make folks feel better about using the + to - methodology.
Being an old dog I find it easier to read a wiring diagram based on the + to - flow of electrons. Or holes if one prefers.
Originally posted by rodbolt17 View Postflow + to - depends on if your civilian trained or military.
why I dunno.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
