1989 115 ETLF, tach display works fine. Trim and oil display works but the tach always displays 0. I wanted to try and find out if the issue is somewhere in the wiring as apposed to a failed tachometer? Help troubleshooting, wire colors to chase, expected voltage, equipment needed to check it, etc. I have a basic volt meter but not much more.
Thanks in advance for any help.
