Originally posted by ThaiWake
View Post
Every little bit helps in your case...
Re water coming out when putting water IN the water OUTLET, the exhaust of course, comes out thru the prop. The water is just bleeding out (with it NOT being attached to the lower leg). That has to be water cooled or it'll cook the prop insert. I suspect that's why water's coming out there.
Not sure if that makes sense(does to me!)..
You likely have some larger o-rings on the ends of the water tube that goes from the LU to the power head. I'd peek at those as well if not too hard to access..
