My motor is a Yamaha F60TLRD. I recently pulled my LU to rebuild the water pump. When I reinstalled the LU and fired it up, my water pump works great but now the motor is stuck in forward.
Pulled the LU off again and have manually manipulated the gear select spline on the LU. (Using the gear selector at the helm seems to work, it moves the gear select shaft about 1/8 to 1/4 inch clockwise/counter clockwise respectively.) I can feel 3 distinct points when turning the spline, but no matter the position, the drive shaft is engaged in forward.
If I use a pliers and rotate the spline to the extreme in either direction it will slip into neutral. Once I let go it slides back into forward. I replaced the gear oil last spring, and just drained it last night. No metal shavings on the plug and didn't smell burnt. From what I have researched, it seems the dog clutch is not disengaging for some reason.
This is my first time working on a LU on an outboard, it seemed pretty straight forward, but now I am stumped. Any suggestions would be greatly appreciated. Thanks.
