I have Yamaha F150 2005 engine's inside the thermostat housing there is some corrosion underneath where the thermostat sits
I am wanting to do some preventative work to stop it going through.
Has anybody tried painting with zinc primer epoxy two pack or galvanised paint to help the corrosion.
tried metal putty did not stick, glass fiber lasted 1 year.
I be grateful for anybody's feedback on what they have done to stop the corrosion.
The engines have had new anodes in each year and have been flushed out every time they have been used using the attached water connection and on muffs for short time as the engines over heat due to low water pressue in the yard.
Any ideas much appreciated. Alistair.
