Looking for a little guidance please. Background is I bought this motor and the previous owner had analog gauges so he would not be of any help.
The center bar is flashing on the tach, despite both tanks being full. I took the harness and the float out of the engine mounted tank and ohm meter to the black and each wire as mentioned in the book for sw1, sw2 and sw3. All checked out when I slide the float. However when I first started sw1 was not registering until I moved it down then back up. Again, each position the meter registered continuity. Checked the boat mounted tank tested ok as well.
Could the float be defective? or should I look elsewhere like the ECU? And is there a test for the unit?
Thanks in advance
Chris
Thanks in advance
Chris
