OK need some advice bought a 2005 skeeter with 300 hpdi.
It seems to run rough at idle when put in gear it smooths out. I know about the idle in 4 cyl that it would run rough.
Here is what has seem to be what I noticed more often then not when the exhaust ports are in the water it stalls out in gear or idle.
If i trim 3/4 of the way out of water it will idle.
So I had a tournament this weekend and when Was getting ready to take off it died and i couldn't start for 5 min just like it ran out of gas.
While trying it just turned no fire held down hot foot and finally got gas and started.
Made a run wot and then went off plane it dies started back up the couldn't get on pad 3k rpms I fished the area 3 hrs later I tried again got on pad then ran fine unless the exhaust was in water.
250hrs always ran with fuel additive and ring free before I start replacing things any ideas please help.
Tks
Tks
