your simply to dense to understand.
lets take a s225 turt and an F225txrb.
one displaces 3.1L the other 3.3 l.
not a large difference.
both produce an advertised HP at about 5500 RPM.
the s motor intakes,copress's,fires and exhausts all 6 cylinders in 360* of crankshaft rotation.
the F motor takes 720* of rotation to accomplish intake, compression fireing and exhausting all 6 cylinders.
means that every other time that F motors pistion comes up its cooling down.
that is the second function of the piston rings on both the s and F motor, dissipate the heat from the pistion to the cyl wall.
in theory the piston never touchs the wall on either engine.
so both engines are burning roughly 25 gallons of gas at 5500 RPM.
one ,the s motor,is fireing and combusting fuel every 5500 times per min.
the F motor does this power cycle only 2750 times for the same 5500 RPM.
yep not a lot of displacement difference between the 3.1L 2 stroke smokey and the F225 3.3L.
world of difference in hole shot and low end grunt.
the 3.1L will walk away from the 3.3 anyday of the week and do circles around it on sunday.
but the latest F225 with a single throttle body AND variable cam timing is another monster.
but ya really really need to understand the difference between two and four stroke motors and how the intake,compress,ignite and exhaust.\
at the end of the day.
suck squeeze bang and blow that's just how they go.
the thermodynamics come in to play so the more heat you can generate WITHOUT destroying it, the more power that same displacement can produce.
yes Virginia,,,, its that simple.
and remember 360* is one circle/revolution.
720 is two circles or two revolutions.
on a 2 stroke V6 one 360* turn of the crank each piston has done a power stroke.
on a four stroke V6 at 360* rotation only 3 pistons have done a power stroke.
the other 3 have been just dragging along.
