My 2002 Yamaha Z150 TXRA runs in safe mode intermittently. This has been going on for several years but has gotten to the point that is is unmanageable. Here are the details - appreciate any suggestion and support.
1 - Sometimes when starting the engine operates in safe mode - no alarms just runs on 3 cylinders. This happens for a cold start or hot start. No over heating no low oil no water in fuel. At first i would have to restart 2 -3 times and it would run normal but it has gotten worse so now it more like 15 plus times. Once running out of safe mode it runs great.
2 - Brought to mechanic and tested the Shift switch - it was good - even took it for a run and played with switch - no difference
3 - downloaded the historical codes
- Code #19 voltage - Assumed this was because the motor was not running. I have no issues with charging
- Code #28 Shift Switch - assumed this was because i had taken it off and run motor with it disconnected from shift linkage
- Code 22 Atmospheric Pressure Sensor - reading 29.4 - accurate for my area that day
So i and the mechanic are at loss for solution. Planning to take it back next week when he has more time.
One suggestion was fuel pressure issues? But motor runs strong and the are no alarm codes for this issue.
Any ideas??
Any ideas??
