i have an oil leak. ther is oil in the cowl on the right frontcorner of the engine,and on the oil pump. i have replaced the oil pump, all seals and gaskets twice and is still leaking. please help !!!
09 f150 txr oil leak
would not be the first crankcase cover to block leak I have seen,
the balancer can leak as well.
clean it off well with simple green or something.
go to napa and get the ultra violet oil detector and add it to the oil.
run the motor and inspect with a black light.
ATF had it in it for many years, but I have no idea if it still does.
Using a black light was in the manuals back in the 70s for looking for leaks in auto trans in automotive vehicals.
An additive to put into most any oil system makes sense.
You can buy CFL black light bulbs most anywhere and install them into any light fixture they will fit into, or buy a hand held specialty light for getting into tight places.
But those were great days
But I preferred drinking as I could keep going,
other things affected to where I did not want to do anythingLast edited by 99yam40; 03-19-2016, 04:58 PM.
Originally posted by catfish80 View Posthey rodbolt have you seen them leak through to the bottom as well ?
The additive is also added to refrigeration systems and sometimes plain gas lines to detect the smallest of leaks with "black" (contradiction or oximoron) lights
ÂÂÂ
