i've got a 2012 FT9.9 LEPL.
In the morning it started as easily as it always has done, ran smoothly with no issues.
In the afternoon, literally the same day, it wouldn't run. Doesn't catch at all.
Motor cranks fine, pulled one of the spark plugs, held against the block and saw sparks, so get to thinking its a fuel issue.
Pulled the fuel pump and pumped the fuel primer, no leak from the diaphragm.
Tried cranking while pumping the primer bulb, nothing.
Even tried some engine start into the air intake, and it still doesn't catch at all.
So I'm back to thinking its an electrical issue, but I'm at a loss as to what to check next.
With it running absolutely fine in the morning, then not at all in the afternoon makes me think it should be something obvious, like a loose connection, but I can't see anything.
Any suggestions on where to look next gratefully received
