Originally posted by TownsendsFJR1300
View Post
2-stroke bogging
Originally posted by scofflaw View Postreread his first post. what he has tried eliminated varnish as his problem
First mechanic re-built them. Problem persists
5 star mechanic states carbs NO good, they replace with another set-(which is BS unless there's something physically wrong with the original ones). Problem persists
The symptoms point towards the carbs. Varnish may be gone, one small piece of crap in a main jet, knocks out one cylinder from running.. .. Wether it got sucked up later, was already in the system, dunno. Vacuum leak, maybe.
There's something wrong in the fuel system IMO..Last edited by TownsendsFJR1300; 03-08-2016, 06:23 PM.Scott
Originally posted by tommmmmg View PostThere appears to be no high speed jets to adjust. Is the float a consideration? These carbs are supposedly good?
Re the float, if they/it leaks, it'll fill with fuel and stay open eventually flooding and fuel pouring out.
If its hanging up and NOT dropping, that will cause your issue (no fuel getting into a bowl)-not likely, but...Last edited by TownsendsFJR1300; 03-08-2016, 06:29 PM.Scott
DUDE
DUDE
and wannabe DUDES.
IF the OP described the issue as it runs poorly UNTIL he PARTIALLY closes the choke, THEN it will run fine WITH THE choke ppartially closed guess what FOLKS??????
it aint a friggen fuel soaked float.
which BTW in 30 years of playing with Yamaha I have NEVER seen.
but THAAAANK MON THAAANK.
IF it runs fine under load with the choke partially closed there IS fuel in the fuel bowl.
this crap aint hard, 5 star means they passed an online video course.
Yamaha made a lot of different carbs.
go ask your mokanic about the back draft or (fuel bowl jets)
he wont have a clue what back draft means nor how long that design from various manufacturers have been about.
typically the rare carbs I had to scrap were salt water damaged, as in they sat with salt water in the bowls for a long time.
