I have a 1998 yamaha 115 2 stroke. What are the acceptable tolerances for both the primary and secondary ohms on the ignition coil. Thanks in advance.
Need to know recommended ohms for ignition coil
dude
its an ign coil not a mystical magical unicorn handler.
typical primary resistance is less than 2 ohms usually less than 1 ohm.
typical secondary resistance is around 2-3k ohms.
works that way with most all ign coils.
Yamaha ign coil failure is very very rare.
Originally posted by louisiana lad View PostYour right, ignition coil is fine. I'm just frustrated and grasping for straws.
Not saying new coil will fix your problem as we don't really know what it is. But if can get hold of another coil free from somewhere try swapping.
Originally posted by rodbolt17 View Postbut
what is wrong?
Â
