For some reason the trim and tilt toggle switch does not work at times. The trim and tilt solenoid will engage, but no movement by the motor. The odd thing is, if you disconnect the switch from it's mounting bracket it works just fine. I think it might have something to do with some sort of ground issue. Any ideas on what the problem may be or how to fix it?
Trim and tilt toggle switch issues
