No electrical
  • No electrical
    Reinstalled my battery after a recharge and getting absolutely nothing.
    Good battery. No tilt/ trim switch, no ignition. Battery switch tests ok.
    Worst thought is maybe I somehow did not connect negative lead last time I had battery connected. Fuses are all good.
    How bad might this be? I am fearing the worst.
    If you accidentally hooked up your terminals backwards probably blew that 20 amp fuse under cowling.....please don't ask me how I know about this!....otherwise your battery cables may have corrosion inside their outer plastic casing....
